I was on there site and I didn't see a way to buy the wheels in the U.S. I'd actually consider them at that priceevan_calgary wrote: ↑Wed Dec 13, 2023 12:41 amMeets most of the requirements! :P They do look nice!Smoker wrote: ↑Sat Dec 02, 2023 11:24 pmYeah. First place I saw was asking $1,335.usd.evan_calgary wrote: ↑Sat Dec 02, 2023 7:44 pm I doubt the 2100 pound cost would fit the 'on the cheap' portion of his inquiry though. Nice wheels.
But they're new, tubeless, and magnesium.
wheel swap?
Re: wheel swap?
Re: wheel swap?
A 3MA is a reverse cylinder TZR250
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
1973 Porsche-VW 914-6
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
Re: wheel swap?
Google.
italianiron.com <--Us located
jlexhausts.com <-- ships to USA
Available at multiple places for delivery in USA.
rippa wrote: ↑Sat Dec 23, 2023 8:01 pmI was on there site and I didn't see a way to buy the wheels in the U.S. I'd actually consider them at that priceevan_calgary wrote: ↑Wed Dec 13, 2023 12:41 amMeets most of the requirements! :P They do look nice!
Re: wheel swap?
Got it thanks guys! I wonder how much it's going to cost to dress the wheels with all the required do dads.
Re: wheel swap?
It will be some work and research. Need to ensure your discs end up in the correct place which may mean finding replacements with the correct diameter and bolt location as well as offset for the new wheels compared to the old. Alternatively you could make a spacer to move the brake caliper. Bearings that match up to the old axles and finally not sure if there is a provision for speedo on those. In the rear have to work out the spacing of the sprocket carrier and rear disc. If you can find someone out there that has done it before or possible ask the seller/ manufacturer if they've got any relevant info for your application it may make things easier as they may know someone that's gone through it before. It may help to read through some of the posts on here with suspension or wheel swaps to see the work involved. Not trying to discourage just be aware it can be some messing around to get them to work.
Re: wheel swap?
Reading this I'm appalled by the Prices... Moto addicts are being Reamed for.
Magnesium alloy wheels for My Maserati in 20" diameter and 10.5" J are Listed at between 600$ and 700$ .
And theres' Nothing inexpensive in Maserarris.
Re: wheel swap?
I contacted a dealer that was very good about keeping in touch with me and helping though the process of buying wheels. Unfortunately it got to the point where they didn't have specs for an RZ 350 so they wanted me to ship my wheels set to Italy so they could measure the wheels etc. I called it quits, the cost just doesn't make sense.
Re: wheel swap?
Sounds like you're willing to pay the regular price for the custom wheels, and you just need the fitment specs.
There are some knowledgeable and generous folks around here, who can help with the specs. Also, the search button is your best friend.
