TZR400 track project
ruka
#31 Post by ruka » Tue Jun 07, 2011 12:41 pm
"all systems go" :smt003
just have to find someone to push. the machine is light and compression high. can´t get it going alone.
ruka
#32 Post by ruka » Tue Jun 07, 2011 5:57 pm
Machine has been trough the first 2 heat cycles without probs.
I am happy :smt003
biofotis
#33 Post by biofotis » Tue Jun 07, 2011 6:47 pm
looks very good...
i have a 3ma and a ypvs and i was thinking to do the same but....
Cant you use the kick start with this frame?
ruka
#34 Post by ruka » Wed Jun 08, 2011 7:52 pm
Don´t know if a kick starter would fit. Probably yes, but it was never ment for it to have one :smt003
Are you planing on parting 2classic 2stroke to make one?
What I did was finding parts, bit by bit.
etienne24II
#35 Post by etienne24II » Mon Jun 13, 2011 4:44 am
Hi Ruka :smt002
Great choice
Is it for track? Your pipes are seriously going to toutch the ground in turns. Take a copper hammer and make an imprint of the rear suspension progression system on your pipes. If it doesn't suffer, make a flat on the outside.
:smt004
ruka
#36 Post by ruka » Mon Jun 13, 2011 10:46 am
hi etienne.
jaaa.. maybe they will touch the ground... but I´ll have to see before I start thinking about what to do.
Anyway.
It´s ready to role... tomorrow and wesdnesday it´s track time.
I would like to send a huge thanks to all in this forum that have helped me through this endeavour. I feel like the meaning behind forums such as this one really came to the surface. People helping other people overcoming motorbike related dificulties.
#37 Post by JonW » Mon Jun 13, 2011 8:28 pm
WOW! I think we might need video of it running :smt003
ruka
#38 Post by ruka » Sat Jun 18, 2011 5:37 am
That might be a bit dificult at the time.
The machine had engine problems.
When a professional builds something that is not std. from the start, then the probability for it to run flowless is quite big.
Amateurs is a bit different... probability for at something goes wrong is quite big, so things should be taken easy at the start.
Part the circunstances, and also me not keeping a better eye on the instruments (wich anyway is hard at 170km/h with 2 race trimed 600s on each side) ment that the engine ended up seizing.
I´ll start rebuild as soon as possible. Hope the damage isn´t very much.
Vollegaaz
#39 Post by Vollegaaz » Sat Jun 18, 2011 6:40 am
nice build Ruka :smt007
sorry to hear the engine seized so quick :smt010
KennyBarroz
#40 Post by KennyBarroz » Sat Jun 18, 2011 7:08 am
wtf?
where do you live?!? Mekonomen, that's a Swedish company :smt003
Well, that build is just a beauty!
Video later on when the bike runs? :)
RD350 F2 -87: SETUP :
Stock 65mm barrels, TSS YPVS kit, 0,9squish, Vforce3 reeds, stock intake for Vforce3 reeds, 28mm PWK custom made for oilpump and vacuum line, jets 120/40, modified airbox, Zeeltronic PCDI-10V - Custom curve
#41 Post by JonW » Sat Jun 18, 2011 9:37 am
sorry to hear that mate! good luck with the rebuild...
pez
#42 Post by pez » Sat Jun 18, 2011 10:30 am
Bad luck mate - what was the cause? Going to take pics of the teardown?
'86 RZ250R w/350 Barrels - daily
'76 RD400C - running restoration
aaronmvrider
#43 Post by aaronmvrider » Sat Jun 18, 2011 10:33 am
ooohhh bad news ... you wouldnt wish it on anyone.. godd luck with it hope its a simple fix etc...
ps... take it easy on the amateurs :smt003 :smt003 we have feelings too
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
wicked motorsports
#44 Post by wicked motorsports » Sat Jun 18, 2011 4:28 pm
uuuhhhhggggg..... Ruka. man So sucks when they run good this happens. Do let the curious minds know cause many on edge with such a sweet looking bike what went wrong? :smt009
Wicked Motorsports Inc.
10552 Stanford Ave.
Garden Grove, CA 92840
The United States
http://www.wickedatv.com" onclick="window.open(this.href);return false;
1-714-530-2215 fax 1-714-530-2217
E-mail: roger@wickedatv.com
ruka
#45 Post by ruka » Sat Jun 18, 2011 7:20 pm
Still haven´t touched the bike.
The symptoms after engine failure are kind of hard to interpret for me, so I'm reluctant about making hypothetical diagnoses. Guess I'll just take it as it comes.
The one scenario I'm kind of expecting is a "run-in" type seizure. Ring gap was set to yamaha book spec, and that with only 3X 10minutes heat cycles, and full bananas afterwards... might be tight, especially if jetting was a bit on the lean side... just a non educated guess, might just as well be anything else as there are a couple of things more bothering me a bit.
@aaron: me one myself. I just ment that a pro is likelly to have the baggage and knowledge, to make decisions and judgements that are essencial when building non std. stuff, where there is no manual to tell, this tolerence is this, or this bit more static compression will want this less timing advance etc, etc...
@kenny: hilsen fra koebenhavn
I´m keen on getting to the bottom of this, to prevent it happening again.
