Led headlight bulbs
Led headlight bulbs
Hi
Has anybody tried LED headlight bulbs in a standard unit? If so how successful are they? I guess space behind the headlight unit might be an issue?
A bit like these.
https://www.ebay.co.uk/itm/201718085929" onclick="window.open(this.href);return false;
Thanks in advance
Pete
A bit like these.
Thanks in advance
Pete
Re: Led headlight bulbs
That seems a good idea.
But I can't determine if 80w/72w is the power of one bulb or of the pair.
If each one is 40w/36w you should go !
Else, the amperage could be too much for the alternator ( pretty sure ), fuse(s) and possibly wires.
Do you spend a lot of time riding in the dark?
Nor particularly, but was thinking off the added benefit of being seen in the day time. Brighter whiter light is probably better than a dull yellow
Not particularly, but was thinking off the added benefit of being seen in the day time. Brighter whiter light is probably better than a dull yellow
- Speed Freak
This original yellow light is the best I ever had...
The contrast is way better than white light
I would never change the original yellow bulb to a modern white one.
My bikes:
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Honda CBR 1000 RR SC57
Yamaha R1 RN04
RD500 YPVS 1GE
RD350 YPVS 31K 1985
Yamaha R1 RN04
Most LED lights can't be used in Europe due to regulations. The cheaper ones are blinding traffic.
I tried a similar LED setup on my RZV but found that there wasn't enough room for the whole LED assembly to fit without modifications so I decided to use a 5500K halogen bulb instead. The LED lights have either cooling fins or a small cooling fan in the rear portion of the assembly which is just a little too long to fit. When shopping for the LED bulb, I tried to find the shortest assembly but it was still too long to mount without modification.
These fit in the headlight bowls, I use these in 4 of my bikes and never any overheating or problems,
https://www.amazon.ca/gp/product/B01F35 ... UTF8&psc=1" onclick="window.open(this.href);return false;
