Mystery Rings
Linx
Mystery Rings
#1 Post by Linx » Sun Jan 07, 2018 1:52 pm
I'm performing a total restoration of my 1984 RD500LC. After completely stripping the bike to get the frame shot blasted and powder coated, I found these 4 metal rings on the garage floor. They measure about 20mm across and have a thickness of a couple of mm. Does anyone know where they go?
Steve.Image
Sent from my HTC Desire 530 using Tapatalk
:smt006 Current Bikes
Past Bikes Include
Rick Lance
Re: Mystery Rings
#2 Post by Rick Lance » Mon Jan 08, 2018 9:55 am
Back on the floor would be as good a place as any. They aren't part of a 500 Yamaha (unless they are a crude aftermarket attempt at imitating an exhaust gasket).
My apologies. I misread the scale. Glad to see you figured it out.
BTW, please make sure that your chain blocks inside the swingarm are a proper fit for the 17 mm axle you are using. The slots in the swingarm where your spacer rings fit should not be carrying any load.
Linx
Re: Mystery Rings
#3 Post by Linx » Tue Jan 09, 2018 12:55 pm
Well I found a home for them. Not standard I'm sure. I thought they might be spacers between the sub-frame and frame but they seem to fit in the swinging arm Axel slots. Maybe I have an RZV swinging arm?
Past Bikes Include
wolfgangh
Re: Mystery Rings
#4 Post by wolfgangh » Tue Jan 09, 2018 1:05 pm
Seems you have a swingarm for a larger diameter rear axle and someone has machined these spacers to fit your smaller axle into it.
phildu31
Re: Mystery Rings
#5 Post by phildu31 » Tue Jan 09, 2018 2:54 pm
Linx wrote:Well I found a home for them. Not standard I'm sure. I thought they might be spacers between the sub-frame and frame but they seem to fit in the swinging arm Axel slots. Maybe I have an RZV swinging arm?
RZV swing arm is the same as RD/RZ swing arm.
Linx
Re: Mystery Rings
#6 Post by Linx » Tue Jan 09, 2018 3:25 pm
God knows what has gone on there then. Everything else fits OK. Are they both alloy?
Past Bikes Include
