I went for a ride today but not far due to no charging. Rode home and started troubleshooting. 2 of the 3 white wires from the stator are broken at the 4 pin connector on the harness side. I pulled all the wires out of the harness and replaced them.
Does the pinout matter for these 3 white wires? Can any of the 3 white wires mate up with the 3 white wires at the 6 pin connector going into the rectifier? They are AC going into the rectifier, are they phased in any way?
Has anyone sourced these 4 pin connectors and pins? Really I only need the pins. None of my vintage connections pins match these pins. If I can’t find replacements I will have to change it out to a different connector on both ends. But this would change the stator cable connector and if I ever replaced the stator in the future the factory connector wouldn’t work, it would have to be changed to mate with the change I make in the harness.
Stator connectors and pins
Re: Stator connectors and pins
any wire can be connected to any other white.
Ive seen the connectors for sale, but dont have a link sorry.
Thank you Jon. I figured as much on the white wires.
Anyone else have a source for these connectors and/or pins?
Ken's Garage
Ken,
Here's a couple to try.
http://vintageconnections.com/
http://www.cycleterminal.com/motorcycle-connectors.html
And one more. http://www.oregonmotorcycleparts.com/connectors.html
Charlie
Charlie
1985 RZ 421 Hybrid viewtopic.php?t=9655
99 R1 USD front end
Tarrozi Hi-rise clipons
TrailTech Endurance II Speedo/Odometer
VJ23 swingarm
CBR F4i rear shock/custom dogbones
JL GP stainless pipes
2018 XSR 900
99 R1 USD front end
VJ23 swingarm
2018 XSR 900
Thanks Charlie. I'm still not finding that particular connector/pins.
I went ahead and swapped out both ends with a standard vintage connections 4 pin.
Back on the road!
Back on the road!
Ken's Garage
