LED Headlight Bulb RZ350
75RD350rider
#1 Post by 75RD350rider » Wed Dec 25, 2019 2:15 pm
Initially I ordered the fan type 9003 LED replacement bulb ( silver one in the picture) and installed it in my 75 RD350 with aftermarket EMGO replacement headlight bucket from Economy Cycle. It works perfect. I figured it would be even easier on the RZ since there are a lot less wires in the bucket. But I was wrong and the fan type bulb struck the back of the bucket. So I ordered the fanless LED. Both pairs of bulbs were around $20 shipped.
The fanless bulb just fits with careful wire arrangement. I test rode both bikes for 30 minutes and all is well.
The lights are very bright. I had some concerns about heat in the fanless bulb but the heat sink was barely warm after 30 minutes of operation so I think it will be fine.
Tim Steele in Front Royal, VA
Moderator
Moderator
Re: LED Headlight Bulb RZ350
#2 Post by silverstrom » Wed Dec 25, 2019 2:36 pm
Do you have links to where you purchased them?
75RD350rider
#3 Post by 75RD350rider » Wed Dec 25, 2019 2:46 pm
Moderator
Moderator
#4 Post by silverstrom » Wed Dec 25, 2019 2:53 pm
Thanks for that :smt006
75RD350rider
#5 Post by 75RD350rider » Wed Dec 25, 2019 3:11 pm
You are welcome!
Zedixe13
#6 Post by Zedixe13 » Sun Dec 29, 2019 12:31 am
You can also use Honda 33120-MF5-751 from a VT500 / VT700 / VT750 / VT1100 and some VF for a straight headlight swap for 73-75 RD350 . Take a standard halogen insert .
Headlight read on the back HM-34 M-S .
75RD350rider
#7 Post by 75RD350rider » Sun Dec 29, 2019 3:04 am
Cool! Good to know.
tacky1
#8 Post by tacky1 » Sun Dec 29, 2019 4:36 am
I use the copper braided led bulbs in all my bikes. They never get hot, not even warm. Great improvement over the stock bulb.
Whymee
#9 Post by Whymee » Sun Dec 29, 2019 1:35 pm
For those that have purchased the Ebay H4 Led bulb:
I suppose I must be easily confused. Do you get one or 2 bulbs with the purchase?
And since I am wondering out loud, anybody know the amp draw of the LED's? Surely must take some load off of the battery.
2.5 RZ350's
2018 Grom
2017 KTM 390
2017 FZ-10
1973 RT3
1974 TY250
plus many others
75RD350rider
#10 Post by 75RD350rider » Sun Dec 29, 2019 2:16 pm
They come with 2
75RD350rider
#11 Post by 75RD350rider » Sun Dec 29, 2019 2:19 pm
Way less than halogen or sealed beam. On my 75 RD 350 you could feel the difference in the motor running down the road with the halogen and if left at idle for long it would draw it down to where it would die. With the LED it runs the same headlight on or off.
Hooligan
#12 Post by Hooligan » Sun Jan 12, 2020 6:12 pm
I bought the LED lights with the braided heat sinks and those do get quite hot if there is no air moving over them. I had planned to put one on my LC but am concerned the hot heat sinks might melt some of the wiring inside the headlight bucket.
The braided heat sink type bulbs are great on my 90 RZ and FZ750, where the heat sinks sit outside of the headlight bucket.
kjellz
#13 Post by kjellz » Wed Jan 29, 2020 6:02 pm
Apart from LED being efficient and all that, I am thinking that LEDs are really no gain for an old bike when it comes to power consumption from the generator or am I wrong?
This is what I figure;
1. The generator is a constant output type
2. The regulator simply sends any excess charge to ground to create heat in order to keep voltage to an acceptable level by voltage drop in the gen windings
3. If you send less charge to head light due to LED, more has to go through the regulator to give the same result at any given rpm.
4 more power through regulator = hotter and more strain to it.
5. Even more risk of damages via poor grounding from the increased amps through this channel
6. Conclusion: no actual powersaving from LED replacements.
7. There are many other advantages by LED still.
Do you agree with me on the above, and if not feel free to pitch in.
Regards
Kjell
RD350 YPVS 1990
pdxjim
#14 Post by pdxjim » Wed Jan 29, 2020 10:01 pm
tacky1 wrote: Sun Dec 29, 2019 4:36 am I use the copper braided led bulbs in all my bikes. They never get hot, not even warm. Great improvement over the stock bulb.
Got a link, Paul?
Wasting time on 2T forums since the dawn of the internet. RD350LC, TDR250, plated 300XCW. No four strokes.
