RD350LC Oil Pump Settings
Moderators: rztom, 2smoke
CDN_RD350LC
#1 Post by CDN_RD350LC » Wed Feb 17, 2021 2:39 pm
So I rebuilt my oil pump and set it up as per the manual. I have run the bike and removed the oil lines to see if they are pumping. I can see oil ever so slowly weeping out. I have smoke... but not as much as I thought. Any thoughts and wisdom about the setup and testing would be appreciated. Thank you in advance.
kpke
Re: RD350LC Oil Pump Settings
#2 Post by kpke » Thu Feb 18, 2021 10:41 am
I can't offer specific oil pump settings for your machine. Someone will soon I'm sure.
Here is a visual reference which may help
https://youtu.be/sBd6ycaRkQk
CDN_RD350LC
#3 Post by CDN_RD350LC » Thu Feb 18, 2021 3:58 pm
Great video KPKE. Thank you. Any suggestions on clear pipe? where people have purchased it from? Cheers
Moderator
Moderator
#4 Post by silverstrom » Thu Feb 18, 2021 4:50 pm
Oil pump output is measured over a set number of strokes. The numbers below are for the RZ350. I would expect similar for the LC.
Minimum Output per 200 Strokes is 0.12 cc to 0.19 cc
Maximum Output per 200 Strokes is 2.58 cc to 2.85 cc
That is going to be at minimum pump stroke and at maximum pump stroke.
Everyone should be doing this test after an engine build or pump removal.
When you install the oil pump you need to manually pull the cable to full stroke to prime the system. It does take a bit of time for the pump to push maximum stroke oil through the lines. You should see lots of smoke at at maximum stroke. If you don't you should look at your pump settings again.
tacky1
#5 Post by tacky1 » Thu Feb 18, 2021 7:53 pm
Check the oil pump stroke with a feeler gauge, I just set mine at 0.25mm,
Check out this
https://rdlccrazy.proboards.com/thread/ ... ke-setting
CDN_RD350LC
#6 Post by CDN_RD350LC » Fri Feb 19, 2021 12:49 pm
Thanks guys for the input. I have ordered a set of clear oil lines from the UK. Will report back. Cheers
CDN_RD350LC
#7 Post by CDN_RD350LC » Wed Apr 07, 2021 9:13 pm
tacky1 wrote: Thu Feb 18, 2021 7:53 pm Check the oil pump stroke with a feeler gauge, I just set mine at 0.25mm,
Check out this
Quick question Tacky1... I got clear oil lines out of the UK. I bled them and they are indeed pumping. My question is, where do you measure your .25mm? It's not totally clear in the manual. Could you post a pic with a feeler gauge? Cheers
tacky1
#8 Post by tacky1 » Wed Apr 07, 2021 11:41 pm
It’s between the washer on the end of the plunger and the top of the pulley. Where the pulley meets the plunger
tacky1
#9 Post by tacky1 » Wed Apr 07, 2021 11:43 pm
Scroll down this thread and there is pics in there :)
