Fairing bolts
Moodeyblue
Fairing bolts
#1 Post by Moodeyblue » Fri Feb 26, 2021 8:08 pm
Hi All
I am completing a restoration on my 85 rz350. The fairing had to be repaired and it is now slightly thicker on the right side where the panels mate.
I m trying to use the original style pan head screws but now I need (2) longer ones that need to be 15mm long.
Can anyone help with a part number from YAMAHA for longer screws with the same heads.
If not, are there other options such as a complete set of replacement screws that will look good.
Thanks for your help.
tacky1
Re: Fairing bolts
#2 Post by tacky1 » Fri Feb 26, 2021 10:46 pm
What’s the part number of the bolt you are using at the moment
Moodeyblue
Re: Fairing bolts
#3 Post by Moodeyblue » Sat Feb 27, 2021 1:47 am
Original hardware. 2 bolts are not long enough after the body work repair.
85RZwade
Re: Fairing bolts
#4 Post by 85RZwade » Sat Feb 27, 2021 2:34 am
There's a method to his madness; given the original bolt's part number, you can determine the part number of a bolt of the same type but longer, shorter, etc.
tacky1
Re: Fairing bolts
#5 Post by tacky1 » Sat Feb 27, 2021 2:45 am
Exactly. I’m trying to figure out which bolts you have. That’ll give us an idea on what you need. Look on Partzilla. Get us the part number
Re: Fairing bolts
#6 Post by JonW » Sat Feb 27, 2021 9:21 am
I also assume you mean a non-USA 1985 bike?
Sadly on the fully faired models the bolt parts numbers dont relate to the length as they have special heads. Its only the normal screws and bolts that contain the lengths etc. Makes it harder.
What you can do is buy stainless bolts with larger heads and use those. they come in varying lengths, just get the length you need.
Evans Ward
Re: Fairing bolts
#7 Post by Evans Ward » Sat Feb 27, 2021 9:40 am
If it is for a US spec RZ, see pic attached. The 06 indicates 6mm size and the 014 indicates 14mm length.
Moodeyblue
Re: Fairing bolts
#8 Post by Moodeyblue » Sat Feb 27, 2021 12:09 pm
i will find the part number and get back thanks.
Moderator
Moderator
Re: Fairing bolts
#9 Post by silverstrom » Sat Feb 27, 2021 4:58 pm
You can buy fairing bolt kits that include many sizes. https://fortnine.ca/en/bolt-fairing-bol ... 09-fairing
You can polish them to match the stock sheen.
Moodeyblue
Re: Fairing bolts
#10 Post by Moodeyblue » Sun Feb 28, 2021 1:20 pm
Thanks, I found a PN from CMS but I dont think the this PN follows the convention for sizing as listed above. (9011005201).
Does anyone know of 5 mm fasteners from other bikes at that would look similar? I could change the whole set.
thanks everyone for your help.
Re: Fairing bolts
#11 Post by JonW » Sun Feb 28, 2021 10:30 pm
Thats what i said above :/
OldTZracer
Re: Fairing bolts
#12 Post by OldTZracer » Tue Mar 02, 2021 9:37 pm
I'm assuming you meant the smaller panel to panel screws, & not the larger panel to frame ones...
The original 90110-05079 socket head subs to 90110-05201. Unfortunately as mentioned above, the length dimension in the Yamaha part number only applies to standard hardware. On "special hardware", they just go to the next available part-number, so you will have to do some detective work. Check mid '80s FZ & FZR & you might get lucky.
I had a couple of 5x15mm Philips head versions that I believe came from the '85 FZ750, but can't remember for sure.
RZtuner
Re: Fairing bolts
#13 Post by RZtuner » Sun Mar 07, 2021 3:36 pm
AMA No.1plate holder x2
