Anyone running 1998-2001 R6 Front End?
Redline Junkie
#1 Post by Redline Junkie » Thu Mar 11, 2021 9:54 pm
Hi
Just curious is anyone is running a 1998-2001 R6 front end on the RZ350?
Wondering about fitment and performance.
Rob
1987 RZ350 Stock
1985 RZ350F basket case
1985 RZ500 Stock
Re: Anyone running 1998-2001 R6 Front End?
#2 Post by MK » Fri Mar 12, 2021 1:54 pm
I do.
Compared to the RGV 250 front end it saved 6 kg and offered adjustments for damping.
So performance is good.
Only thing was that you need to modify the lower yoke to carry appropriate bearings for the RZ frame.
Plus some custom end stops need to be fabricated.
crogthomas
#3 Post by crogthomas » Tue Apr 20, 2021 11:50 am
As a matter of interest how does the lower yoke need to be modified?
RD350YPVS LC2
#4 Post by MK » Tue Apr 20, 2021 12:26 pm
I pressed out the tube, welded and re-shaped to have appropriate length / diameter for the RZ frame.
crogthomas
#5 Post by crogthomas » Tue Apr 20, 2021 1:02 pm
Thanks. I'm looking at R6 forks, so it's good to know what work is required.
RD350YPVS LC2
tacky1
#6 Post by tacky1 » Tue Apr 20, 2021 1:33 pm
Doesn’t all balls bearings do a conversion for these to fit or is it for the 500.
Yellow and Black RZ
#7 Post by Yellow and Black RZ » Tue Apr 20, 2021 2:23 pm
To use the R6 stem you'd have to make a spacer to make up for the extra stem length and use conversion bearings.
If you want the spacer at the bottom of the stem you have to make sure there is enough pressed fit area above the spacer for the bearing.
If thats an issue you can split the spacer in half and place one spacer above the top bearing and the other below the bottom bearing.
-----------------------ID-OD-Height
RZ350 Top Bearing: 25-48-13
RZ350 Bottom Bearing: 30-48-12
R6 top and bottom: 30-55-17
RZ350 with R6 forks Top and bottom conversion bearing:
RZ350-R6 Conv Top: 30-48-12
RZ350-R6 Conv Bottom: 30-48-12
Alls Balls Part Num: 99-3515-5 (Need 2).
Reference:
Alls Balls fork conversion page: https://www.allballsracing.com/forkconversion
Alls Balls steering bearing size chart: https://www.allballsracing.com/media/pr ... eChart.pdf
For my GSXR stem I used 2 spacers. One on top one at bottom.
I could lower the clamp but I’m going to lower the front end a bit and want to limit the amount of fork tubes sticking up through the triple clamp.
'85 RRZ350 - Hacked.
crogthomas
#8 Post by crogthomas » Tue Apr 20, 2021 5:35 pm
That's excellent, thanks. I was mainly wondering if the R6 stem diameter was too large to fit a bearing in. Question answered.
RD350YPVS LC2
Redline Junkie
#9 Post by Redline Junkie » Tue Apr 20, 2021 9:47 pm
Thanks MK & Y/B, this is great information. I have a high performance riding academy at the end of May and I would love to have this conversion in time for that. I have the FZ600 swingarm and SV Rim ready for the rear!
1987 RZ350 Stock
1985 RZ500 Stock
