Lost key
Re: Lost key
number is on bottom of ignition, hunt for that number.
Re: Lost key
That's rare, but it happens.
Find a yamaha key that fits in the lock (they are A thru F shapes, look that up on here), strip it apart and adjust the tumblers (again info is out there, no sense repeating it) and you'll have a working lock with a yamaha key.
Re: Lost key
So if I don’t find the key; does anyone know how to get the fuel filler cap off?
Re: Lost key
Pick the lock, The Yamaha locks are a doddle to pick, Couple basic tools and look it up on YouTube, Ive become a dab hand at picking locks :D :D
Re: Lost key
I think you will find the number on top of the lock, take it off the triple clamp. Any competent locksmith should be able to make a key with that number.
Re: Lost key
Well the lock is open, I picked it and it was surprisingly easy. I’m not sure how to get it any further apart than this in order to re-key it, any hints?
Re: Lost key
I got it, I just have to find a key blank now
Re: Lost key
You will need to find the right blank, There are a bunch of different blanks
https://www.carlocksandkeys.com/1980-19 ... ey-blanks/
https://www.yfzcentral.com/threads/igni ... 17&slide=0
Re: Lost key
I’ve got all six coming because I really have no idea what I’m doing! but with a little help I’ll get there eventually
Re: Lost key
To rekey something you need a cut key, not a blank.
The blanks will help tho, they will tell you what type of key you need A-F. Then find an original key of that letter (lots of ebay with lock sets) and play with the tumblers to make it work. Lots of info out there about rekeying, its fiddly but rewarding.
Re: Lost key
I think with a vernier caliper and some jewelers files I can cut a key to match the existing lock
Re: Lost key
Remove the tumblers. Insert any key you have. Move the tumblers until you find a combination that allows the tumblers to stay retracted with the key inserted. Use as many as you can make fit. Often you'll get at least 3 that will work. The others you don't need. Or do as I do and simply remove all of the tumblers so it will work with any key.
Do the other locks the same way. It's easy to do.
