rz350 porting
turboboy
rz350 porting
#1 Post by turboboy » Wed Aug 31, 2022 6:06 am
Trying my hand at some port clean ups.
No timing changes yet.
Any hints on opening up more on intake.
kpke
Re: rz350 porting
#2 Post by kpke » Wed Aug 31, 2022 10:06 am
Here is what I did turboboy.
https://youtu.be/JqS_IJEzxAY
There is also a video case matching.
turboboy
Re: rz350 porting
#3 Post by turboboy » Fri Sep 02, 2022 3:39 am
Thanks for that
turboboy
Re: rz350 porting
#4 Post by turboboy » Fri Sep 02, 2022 3:39 am
Thanks for that
kpke
Re: rz350 porting
#5 Post by kpke » Fri Sep 02, 2022 9:29 am
:smt023
and
:smt023
tacky1
Re: rz350 porting
#6 Post by tacky1 » Fri Sep 02, 2022 8:01 pm
The ports look pretty stock, Just cleaned up..
This is the porting on one of mine..
turboboy
Re: rz350 porting
#7 Post by turboboy » Sat Sep 03, 2022 4:28 am
Nice would you happen to have port heights
jumjum01
Re: rz350 porting
#8 Post by jumjum01 » Sun May 28, 2023 1:33 pm
Is it possible to port cylinders and gain hp and not just move power (gain high at rpm, lose at low rpm)
Re: rz350 porting
#9 Post by MK » Mon May 29, 2023 1:57 pm
You're a candidate for purchasing an EngMod2T license.
I've used that to optimize components to each other like the port positions with long rod stroker cranks or find a good pipe design for an existing engine state.
Here you can play with any of the influencing parameters before screwing up some valuable original cylinder.
The RD cylinder massivly lacks blowdown. Adding to aux ports on the exhaust is most beneficial mod that'd fulfill your demand.
You may try that on a pair of these:
https://a.aliexpress.com/_Exn7TNn
The above porting work is more or less in the homeopathic 10 -15 % plus range. It'd only gain the full potential in combination with pipes, heads, ignition and maybe some more CC's.
If you don't already have it: There is a tuning manual available for the RD 350 YPVS models.
I'll leave the commenting for someone else as the author may be too biased to give a trustworthy rating.
jumjum01
Re: rz350 porting
#10 Post by jumjum01 » Fri Jun 02, 2023 12:10 pm
EngMod2T seems like a cool/helpfull tool. I would love to get a licence, but its expensive when I only have one 2stroke bike. I did a stroke and bigbore build on my Hayabusa with success. It would be fun to make the RD350 a +4mm stroker :smt045. It seems like the best setup is to get longrod stroker crank, +5mm 795 pistons and mill the head 2mm. Do you have a "stock bike" vs. +4mm dyno simulation in your arsenal? :smt040
