I really only need the O-rings and may have found them. But I also found a great deal (not what I show here) for the banshee ones.
Has anyone successfully used OEM Yamaha banshee float valve assemblies to replace stock RZ350 float valve assemblies?
This is in US model carburetors.
This is what mine looked like
Here is the banshee ones
Stock float valve replacements
Re: Stock float valve replacements
Here is the OEM RZ parts
Ken's Garage
Along the same line- I need needles and seats for a Canadian model- anyone know if the US and Canadian carbs use the same seats and needles- and also float bowl gaskets. The carbs have Dynojet kits in them so I don't need any of the other stuff that comes in a standard rebuild kit that you see on ebay, etc.
This is probably why the left carb just pours gas out when I try to start it now...
- tn_PXL_20221018_223621721.jpg (119.04 KiB) Viewed 914 times
85 RZ350 red/white
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
My research has come back with the banshee parts and the RZ parts are interchangeable. But have not physically verified this. I ordered some float valve assemblies through Yambits. A bit of a risk but I need a bunch of other stuff so threw those on the order.
Ken's Garage
I may try these. Usually the Japanese made kits are pretty good. These are the Banshee kits... Float bowl gaskets look correct as do the needle valves which is all I need.
https://www.ebay.com/itm/154596025656
85 RZ350 red/white
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
