oil pump
oil pump
Decided to take the oil pump apart and check everything and replace seals while the engine was apart. This is a 4K mile bike that had never been touched so I was surprised to see this when I took the oil nipple off to check the ball/spring. Must have been done at the factory. Apparently didn't affect the flow to the carbs but did keep the ball open all the time. Can't even imagine how it could have happened.
- tn_PXL_20230811_165846887.jpg (206.08 KiB) Viewed 490 times
85 RZ350 red/white
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
Re: oil pump
I've seen that a few times, don't know how it's caused. You will almost definitely need to replace the corresponding valve seat as this condition will damage it, and it will always pass oil.
Re: oil pump
Arrow, is there supposed to be oil in the worm drive section of the pump? I rebuilt it while the bike was apart and checked the clearance and all was good but I pulled it since I'm replacing the water pump seal and a bunch of oil came out.
- tn_PXL_20230904_230322511.jpg (90.7 KiB) Viewed 421 times
85 RZ350 red/white
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
85 RZ350 yel/blk
86 VFR750F
77 CB750F
73 Kaw S1
72 CT70 190cc
86 Z50R
